ConanR's avatar
ConanR
Re: netgear 450n/cg3000dv2 not routing
Just got a different Mediacom bundled service w/phone. Modem router working fine up to now. Now can't get in with 192.168.0.1 unless disconnected from cable and reset to factory defaults with PC set ...
  • DarrenM's avatar
    May 01, 2018
    It sounds like the ISP does not have the coding correct on the modem they may need to remove the modem from there system and add it back. You may want to talk to your ISP and ask for a higher level of internet support.
    DarrenM
