mattoram
Jul 14, 2021Tutor
Netgear cm 1200 Intermittent connection
I am having problems with my internet connection getting dropped a lot somehow. I'm not very educated on how all of this works and know only the very basics. On all of my connected devices, a...
- Jul 27, 2021
Well Netgear sent out a new modem and everything has been working perfectly for about a week, so far. The event log has been completely clear with no errors.
mattoram
Jul 15, 2021Tutor
Xfinity just tested all of the lines and signals, and everything is working on their end. It looks like the modem may be the issue. Now I need to figure out if it needs to be replaced, repaired.
vkdelta
Jul 16, 2021NETGEAR Employee Retired
actually, there is noise in line which is causing T3 timeouts.
you should get internet service but it will go out momentary when there are T3 timeouts.
US power is on the higher side as well.
you can try renting the modem and almost certain will see the same issue. you can ask them to fix the problem.
- mattoramJul 17, 2021Tutor
The Xfinity/Comcast technician came out yesterday and tested the signal and connections, and said everything was fine. Neither Netgear or Xfinity asked to look at the logs or modem parameters. It's frustrating because I don't think they really know how to find and fix this issue. I would happily pay a qualifed person to diagnose and fix this. I won't be able to get anyone out this weekend, so I'll wait for the new modem and install it on Tuesday and see if anything changes. If it works great, if not, I'll have to find someone that knows what they're doing or learn it myself. I'm an engineer and I'm sure I can eventually figure it out but I have nearly no knowledge of any of this, at this time.
- FURRYe38Jul 17, 2021Guru - Experienced User
IF you have a chance too, rent the ISP modem they provide for a short while and see if the problem continues or not. Kind of best way to help trouble shoot this. If the problem continues even with there hardware, then the ISP needs to fix it. If it doesn't then there maybe a faulty CM modem you have that needs to be replaced...
- mattoramJul 19, 2021Tutor
Thank you, I'm actually picking up a modem from Xfinity tomorrow. I'll keep you all posted.
