GearNet7
Oct 01, 2024Aspirant
Re: New - CAX80 Firmware Version 5.1.1.8 Released
Anyone who owns CAX80, do not use this firmware. Unfortunately for me, the firmware was automatically updated for me last night and it completely brought my unit to its knees, so much so that I r...
GearNet7
Sorry if I wasn't clear in my previous post. First off, the automatic update completely ruined my original setup. It was since then I had to perform a factory reset, and only then I tried to reconfigure everything. So yes, I understand this is a major release but still port forwarding was broken, period.
That being said, NG should have thoroughly tested their fw before releasing it to the public. Most consumers who purchased this would not have nearly the same level of knowledge as I do, let alone they would know or even bother to roll back the firmware to the previous version.
Suffice to say, this level of software QA is unacceptable.
Kitsap
Oct 01, 2024Master
GearNet7 wrote:Sorry if I wasn't clear in my previous post. First off, the automatic update completely ruined my original setup. It was since then I had to perform a factory reset, and only then I tried to reconfigure everything. So yes, I understand this is a major release but still port forwarding was broken, period.
It is normal for experienced Netgear users to turn off automatic firmware updates. If you were not one before an automatic update blows up your network, you soon become one after.
I am not saying it is right, I am saying it is a cold hard fact with Netgear routers.
- GearNet7Oct 02, 2024Aspirant
Needless to say, my unit received the automatic update once again last night and as the result, it screwed up all port forwarding.
I try to find the automatic update option but I cannot find it. Is there any other secret menu option that I can enable to turn it off (like the developer mode on Android phone, for instance)?
- KitsapOct 03, 2024Master
GearNet7 wrote:Needless to say, my unit received the automatic update once again last night and as the result, it screwed up all port forwarding.
I do not have a CAX80 available to check on the specific page. Maybe FURRYe38 can shed some light on this question. There is also a chance that option has been depreciated in the most recent firmware release.
