chubaan
Apr 08, 2024Aspirant
Re: New - RBR750 / RBS750 Firmware Version 7.2.6.21 Released
Hello. I purchased the kit CBK752. I see in orbi app the satellite shows as RBS750 and the cable modem shows as CBR750. I have manually updated the satellite to fw v7. But if I search for CBR750, it ...
- Apr 08, 2024
v7 is NOT compatible with the CBR750. Please review this:
Apr 08, 2024Guru - Experienced User
- chubaanApr 08, 2024AspirantThanks for the quick response. Any other way to enable IoT?
- FURRYe38Apr 08, 2024Guru - Experienced User
Unfortunately no. Some have used the Guest Network for there IoT device. Up to you if you want to use that.
Option would be to get a RBR750, load the RBS750 with v7 FW, Load the RBR750 with v7 FW, configure the CBR for modem only mode then you'll have the separate IoT network that v7 provides.
- chubaanApr 08, 2024AspirantThanks. Lastly, It said that:
"Since the CBR version of FW is not fully synced between the CBR and RBS, we can use the RBS FW from the RBK or RBS sites with this FW version for the CBR750."
Since I've already upgraded the RBS750 to v7, and I'll be leaving the CBR750 to v4, it should be fine right? I don't need to change the RBS fw version back to v4?
