Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
Nov 10, 2021Guru - Experienced User
I recommend you send them to a forum Moderator and NG engineering will need to look into the logs. Hopefully they will be able to see the problem and get it fixed.
dv8withn8 wrote:
Ok, debug logs saved. Is there a specific thing you're looking for? It generated a lot of files.
olympos1625
Nov 10, 2021NETGEAR Employee Retired
Hi dv8withn8,
I would like to endorse you to NETGEAR Level 2 support team for callback. Please DM the following information:
Name:
Email:
Phone:
Preferred schedule (atleast 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
- FURRYe38Nov 10, 2021Guru - Experienced User
