jsomaini
Jul 18, 2024Aspirant
Re: Nighthawk CAX80 login loop
I have the same issue. When trying to authenticate to the web service (on the router), it forces a reauthentication. Eventually, it asks for the serial number to reset the pw. Even after doing tha...
Jul 18, 2024Guru - Experienced User
have you made sure the password meets these requirements?
10 characters with at least:
1 special character
1 upper case
1 lower case
1 number
jsomaini
How can you backup the config if you can't log into the web interface? (hence the issue we are having).
Thanks
