Wolfa
Nov 12, 2023Aspirant
Port Forwarding CAX30 just doesn't work...need help please.
I've followed all the tutorials on how to properly Port Forward this router. I'm trying to run an Ark: Survival Ascended Server and i have set all of the ports to be forwarded. However when i go onli...
Wolfa
Jul 04, 2024Aspirant
There is nothing.. .even when i try to connect to the server on the same pc the server is running on i get Unable to Query Server Info for invite. Network Failure Message.
Razor512
Jul 05, 2024Prodigy
That is strange, especially if LAN to LAN and even 127.0.0.1 on the same system hosting the server, often that indicates more of a software issue, since 127.0.0.1 doesn't even touch the router, and LAN to LAN on that router behaves like an unmanaged switch where nothing is blocked, and port settings should have no impact on, with the exception of the guest network.
