nighthawk1234
Jul 21, 2024Tutor
Re: Roborock Q Revo won't connect to Orbi wifi
Hello! I am having a similar problem. I just "upgraded" from a Nighthawk C7000v2, to the Orbi CBR750. The Nighthawk has two separate wifi bands for the 2.4 and 5 Ghz wifi. The Orbi seems to have...
- Jul 25, 2024
Since the CBR is a MESH system, both 2.4 and 5Ghz have Smart Connect enabled into one SSID name. The CBR doesn't support disabling of Smart Connect or separating of the SSID names.
Try this. Turn OFF all RBS. Then turn the power output of the 5Ghz radio to 25% on the CBR. Be sure that 20/40 MHz Coexistence enabled. Under Advanced Tab/Advanced Settings/Wireless Settings. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Or keep an old router on hand that can actually turn off the 5G WiFi band. Plug in this old router and give it exactly the same WiFi credentials as the Orbi WiFi. Connect the smartphone to it and do the setup. Once the setup is completed, just power OFF the old router. Your devices will auto connect to the Orbi system.
nighthawk1234 wrote:
Hello! I am having a similar problem. I just "upgraded" from a Nighthawk C7000v2, to the Orbi CBR750. The Nighthawk has two separate wifi bands for the 2.4 and 5 Ghz wifi. The Orbi seems to have a single stream and the roborock vacuum is not able to connect. It seems that because i cannot have my phone connected directly to a 2.4 connection the vacuum cannot find that 2.4 connection either. That is just my theory. If you have any suggestions please let me know.
nighthawk1234
Jul 21, 2024Tutor
Hello, Setting up the old modem/router did not work. As I do not have access into the admin site for it and I tried connecting it to the new orbit modem/router as a stand alone router. It came up with the 2.4Ghz wifi, but it would not connect to the internet. I then tried setting up with my iPad and using phone as a hotspot. Vacuum set up went further, but ultimately failed to connect.
Would you mind explaining a bit further so I have a better understanding?
Thank you for your help!
Jul 21, 2024Guru - Experienced User
What failure is the Roborock giving you?
Did you contact Roborock?
Is ipv6 enabled on the router?
Did it setup using the phone's hotspot? And you used the exact same ssid/password as the orbi? (turn off the orbi when doing it).
