AP747
Jan 17, 2025Aspirant
Re: Signal Level Check for Xfinity Connected CM1200
Hi can someone advise on whether the downstream signals look acceptable? Ive had occasional drops (few times per month) tied to SYNC Timing Synchronization Failure errors. I read that +/- 7 is the ra...
Jan 17, 2025Guru - Experienced User
For only having an uptime of 12 hours, that's a lot of errors.
Check all your connections. If you've got a double splitter, try putting that in the line and ensure the barrels are tight.
