AP747
Jan 17, 2025Aspirant
Re: Signal Level Check for Xfinity Connected CM1200
Hi can someone advise on whether the downstream signals look acceptable? Ive had occasional drops (few times per month) tied to SYNC Timing Synchronization Failure errors. I read that +/- 7 is the ra...
AP747
Thank you. I note that the levels I showed you are with a 6 FPA attachment. I just added a -10 FPA on top and the numbers now look like this as a result. It’s definitely a signal with too much power downstream. Thanks for confirming my suspicions. I also have the cable company (OPTIMUM) coming over tmw to replace the exposed coax outside my house (extreme cold cracked the coax and can see the metal sheath) and the splitter connections that they are responsible for is corroded. They DONT maintain anything unless they have to 🙂 Go figure.
Jan 17, 2025Guru - Experienced User
Way better now.
Have them check it all out.
Good Luck.
