SwellVermin
May 02, 2025Aspirant
Re: Switched from CM3000 to CAX80 and it destroyed upload/download speeds
Hi all. I too am having issues getting the downstream fully bonded, however I am on Cox. The demarcation line from teh street comes directly into my smart box. The dmark line has a MOCA filter th...
SwellVermin
How to resolve the correctables and uncorrectables in the three specified channels? I have tried removing the MOCA filter and using the dmark line direct into the modem. This yielded 30mbps download speeds. Put it back to the way I have it as described now, and I get about 700mbps dl. I pay for 940mbps. The only thing I havent tried is using the -7db output from the splitter and/or replacing the 9 year old splitter.
May 02, 2025Guru - Experienced User
Something to to try.
Have the ISP take a look as well.
- SwellVerminMay 02, 2025Aspirant
Yeah, I have been unable to get them to come out bc they are adamant that its a Netgear HW issue. I guess the squeaky wheel gets the grease...smh
- FURRYe38May 02, 2025Guru - Experienced User
Yep.
Was the CM modem doing same thing when you had it online? CM3000 is a solid modem.- SwellVerminMay 02, 2025Aspirant
Its online and working fine. Just wont fully bond the downstream. When I turn on the router after power cycling the modem, is when it becomes unbonded....weird.
