T369
May 10, 2024Guide
Re: Trying to view eMTA Event Log causes reset on my CM2050V modem
I happened to click on the event log while troubleshooting and my internet locked up. That's when I noticed that my modem restarted. Even after a restart it's still doing the same thing. Is there sti...
Miked2
May 10, 2024Apprentice
Nope - Netgear does not seem to fix stuff, and they charge for tech support to report the issue.
May 10, 2024Guru - Experienced User
NG is aware of the issue. No idea if or when that will be addressed. Takes a while for issues to be fixed and then tested and certified with the ISP. Takes time. Please be patient.
