duckware
Oct 18, 2021Prodigy
What does "CCAP Commanded Power in Excess of 6 dB Below..." mean?
"RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW" means exactly what? Often seen with "Dynamic Range Window violation" and "Started Unicast Maint...
- Jun 28, 2022
Finally, after a ton of tech visits, the ultimate problem causing this issue has been found: A bad cable from the top of the telephone pole (at the tap) running 15' to the base of the telephone pole (ground block). For full details (and more), visit: https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
duckware
Oct 18, 2021Prodigy
2021-10-16, 12:33:33 Warning (5) Dynamic Range Window violation
2021-10-16, 12:33:33 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=(MAC);CMTS-MAC=(MAC);CM-QOS=1.1;CM-VER=3.1;
2021-10-16, 12:33:30 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=(MAC);CMTS-MAC=(MAC);CM-QOS=1.1;CM-VER=3.1;
2021-10-16, 11:14:17 Warning (5) Dynamic Range Window violation
2021-10-16, 11:14:17 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=(MAC);CMTS-MAC=(MAC);CM-QOS=1.1;CM-VER=3.1;
2021-10-14, 12:02:10 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=(MAC);CMTS-MAC=(MAC);CM-QOS=1.1;CM-VER=3.1;
2021-10-14, 11:52:11 Warning (5) Dynamic Range Window violation
2021-10-14, 11:52:11 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=(MAC);CMTS-MAC=(MAC);CM-QOS=1.1;CM-VER=3.1;
2021-10-14, 11:27:35 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=(MAC);CMTS-MAC=(MAC);CM-QOS=1.1;CM-VER=3.1;
2021-10-14, 11:27:33 Warning (5) Dynamic Range Window violation
2021-10-14, 11:27:33 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=(MAC);CMTS-MAC=(MAC);CM-QOS=1.1;CM-VER=3.1;
duckware
Oct 18, 2021Prodigy
