JordanBeckett's avatar
Jun 25, 2019
ReadyNAS 424 Adding Disks to Existing Volume
Hey Everyone!
Quick question -- maybe it's simple, but I want to make sure I'm understanding X-RAID correctly:
I currently have a RN424 with 2x8TB.
I also have 2x4TB each with data that is being copied to the NAS.  Once this copy is done, I'd like to integrate the 2x4TB into the current RAID.
If I add these two disks, can the current volume be expanded without reformatting the 2x8TB (containing the precious data copied from the 2x4TBs)?
Just want to double check before I do something potentially risky. Thank you so much for your help!
All the Best,
Jordan
www.jordanbeckettphoto.com
  • FURRYe38's avatar
    Please post about this in this forum for your ReadyNAS:
    https://community.netgear.com/t5/New-ReadyNAS-Users-General/bd-p/readynas-general
    Good Luck.
    JordanBeckett wrote:
    Hey Everyone!
    All the Best,
    Jordan
    • antinode's avatar
      antinode
      Guru
      > Please post about this in this forum for your ReadyNAS: [...]
         Did you notice that his other post, which first appeared here, too,
      got moved to the right place without your "help"?  Want to know how?  It
      was easy: A simple message to the moderators ("ReadyNAS"), using "Report
      Inappropriate Content".
            No senseless quotation of the whole message.
            No duplicate postings.
            No wasted space.
            No pointless and unhelpful "My Setup [...]" garbage.
            No annoying animated icon.
         You really should try it some time.  Or is providing actual help not
      what you're trying to achieve?  I wonder what is.
      • JordanBeckett's avatar
        JordanBeckett
        I didn't notice the post was moved. Not sure about that other stuff. Thanks though.
