minglegs's avatar
minglegs
Follower
Sep 02, 2020
ReadyShare - I seem to have broken it by removing my Thumb Drive
I recently purchased a C7000v2 and just tried the Readyshare capability with a thumb drive. I did this as a quick check to see how things work.
I was able to access the content from 2 different computer systems using the \\readyshare capability. Great! I'm happy.
I then prepared my actual source thumbdrive and swapped out the original USB stick.
Went back to my computer(s) and was NOT able to see the thumbdrive. Executing \\readyshare and I get a Network Error 0x80070035 (Network path was not found). Same on both computers.
I now suspect that I screwed things up by not properly (safely) removing my original USB stick.
As a hail-mary I swapped back to my original USB hoping things would revert back...no luck....I get the same error now for both USB sticks.
So now I'm stuck and can not get Readyshare to work at all.
How can I reset / recover from this?
No RepliesBe the first to reply
