ahalmay
Dec 19, 2017Aspirant
READYSHARE not recognizing USB
Out of nowhere, my external HD disappeared on the network. I couldn't find it on explorer, Genie, or Readyshare Vault. However, I could ping the address (192.168.0.5). I am on Windows 10, and usin...
InTheSprings
May 24, 2018Aspirant
Were you able to fix the issue?
I just encountered the same this week.
ahalmay
I purchased a uShare™ Mini NAS Adapter, and connected my USB HD to an ethernet port.
- InTheSpringsMay 24, 2018Aspirant
Thanks for the prompt response.
Ah, that means another power consumer and addt'l costs.
I imagine you did a good amount of digging.. should I find a solution, I'll be sure to let you know.
