ng7457
Apr 08, 2022Follower
Readyshare showing up as an Attached Device
 Hello,     This is a post about a NightHawk AC1900 Wi-Fi Cable Modem and Router, model C7000 v2.     My Readyshare server is not enabled in the advanced settings of my router, and I have not set up a...
fullbright
Jul 16, 2022Aspirant
I just wonder if you found a permanent solution to this issue.
- olympos1625Aug 05, 2022NETGEAR Employee Retired
HI @fullbright,
Welcome to NETGEAR Community!
Thank you for reaching out. Are you having a similar issue as well? Do you have the same cable modem model?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- fullbrightSep 04, 2022Aspirant
Yes, I have the same problem.
I also made another post about this problem. You can check "Re: wired readyshare"
There are many other posts in this community forum but there is no clear working solution at all.
