ng7457
Apr 08, 2022Follower
Readyshare showing up as an Attached Device
 Hello,     This is a post about a NightHawk AC1900 Wi-Fi Cable Modem and Router, model C7000 v2.     My Readyshare server is not enabled in the advanced settings of my router, and I have not set up a...
olympos1625
Aug 05, 2022NETGEAR Employee Retired
HI @fullbright,
Welcome to NETGEAR Community!
Thank you for reaching out. Are you having a similar issue as well? Do you have the same cable modem model?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
fullbright
Sep 04, 2022Aspirant
Yes, I have the same problem.
- fullbrightSep 04, 2022Aspirant
I also made another post about this problem. You can check "Re: wired readyshare"
There are many other posts in this community forum but there is no clear working solution at all.
- olympos1625Sep 09, 2022NETGEAR Employee Retired
Hi fullbright,
Our support team is looking into this issue and would like to work with you
We would like to endorse you to NETGEAR Level 2 support team for a callback. Please DM the following information:
Name:
Email:
Phone:
Preferred schedule (at least 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
