ng7457
Apr 08, 2022Follower
Readyshare showing up as an Attached Device
Hello, This is a post about a NightHawk AC1900 Wi-Fi Cable Modem and Router, model C7000 v2. My Readyshare server is not enabled in the advanced settings of my router, and I have not set up a...
fullbright
Sep 04, 2022Aspirant
Yes, I have the same problem.
fullbright
I also made another post about this problem. You can check "Re: wired readyshare"
There are many other posts in this community forum but there is no clear working solution at all.
