netspert
Jul 23, 2019Aspirant
Readyshare Speed
Yes, it is an old model - but I'm on Comcast in a small town. I have a 1TB SATA2 drive in a USB SATA3 housing with a USB 3.0 interface, connected to the C3000 with a USB 3.0 cable. I would expect t...
- Jul 31, 2019
If they had implemented USB 2.0 High Speed, It would have been quite adequate for the home user - but apparently you need a newer model for that. Why did I have such an old model? It was what Comcast supplied me with - and will soon be gone.
netspert
Jul 25, 2019Aspirant
Actually, downward compatibility is part of the USB standard - but you could be right; my old USB disk housing was USB 2.0, and that systtem worked better than this one with a newer and faster USB housing and HDD. But there is no problen with the USB 3.0 housing running on a USB 2.0 port - file trransfer runs at 200 mbps when I plug the new housing into a USB 2.0 port on the PC - that's fast enough for access to a backyp storage device. But the old USB unit only supported PATA drives, and I ran out of those. This one (LaCie) at least has air holes for cooling the drive. But I cannot find a solution for the 20X performance loss; file transfer running at 11 mbps (a number I've seen mentioned elsewhere in these many pages of Readyshare performance complaints) is a pathetic rate when you want to use it for an online backup drive. And I don't see any decent answers, other than yours - that the modem/router can't handle a USB 3.0 device that is running on 2.0 speeds to accomodate the Netgear unit. I don't think I will buy a Netgear uhit again.
Jul 25, 2019Guru - Experienced User
It is what it is.
Yes USB is supposed to be backwards compatible however implementing it on either host or client device is up to the Mfr of each. I presume in this case since your working with a non USB 3.0 modem and the client device is 3.0 supporting, seems like this is the area of problem. Remember if the modem supports 2.0 then 2.0 would be a max USB connection on the modem. Weather or not the connected client device supports 3.0 and how it handles backwards compatbility will be up to that Mfr. It's possible the Mfr didn't fully support any backwards compabtility.
I ran in to a similar situation with a D-Link DWA-192 wireless adapter. It's a USB 3.0 connection adapter. However it would not work right on my Mac Book Pro 2008 that only supports 3.0. Even though 3.0 was supposed to be backwards compatible, the adapter has expectations of volatage needed for 3.0 operation which my Mac Book was not tuned to give. Installing on my Mac Mini 2012 works just fine since it supports USB 3.0.
So the modem is going what it can only do. How the device is handling the connetion is another problem which falls on the Mfr.
I tend to not use USB on Routers or Modems for any file stroage solutions. Maybe some small stuff, however ideally to get best performances for storage solutions, NAS is the way to go. I got my first NAS several years ago and haven't looked back at USB since.
- netspertJul 25, 2019Aspirant
You are pointing to the same culprit - the Netgeat monem/router - that advertises its use as a way to connect a shared HDD on a small LAN - wireless and wired. But if it cannot do better than 11mbps on a wired Gigabit LAN, what use is it? But you did hint at an erroneous assumption - this USB HDD housing has its own 1.5A ,12v power source - I need to change connectors on the 2.0 Amp one I want to use, but it works fine anyway, when plugged into the PC, on either USB 3.0 or USB 2.0. It's just slow on Readyshare.
- FURRYe38Jul 25, 2019Guru - Experienced User
I pointed to the fact the the limit on the Modem is 2.0. Also metioned that how the 3.0 device handles the backwards compatibility is also a factor.
Again. NAS is the way to go. Find one and you'll never look back.
Good Luck.
Undoubtably a better way to go, just pricier. Still, Netgear does advertise Readyshare as a way to do this - but not well, apparently. I'd love for someone to prove me wrong and let me know how to make it work better.
