Joshipp
Dec 01, 2021Aspirant
ReadyShare USB Drive - Unable to Write to Drive from MacBook Pro
I can connect to and read my files with no problem from the connected USB drive. My problem is when I try to write to the drive. First it asks me to log in. The only login it will accept is the user ...
Joshipp
Just in case it helps, my MacBook Pro is a MacBook Pro (Retina, 13-inch, Late 2013), Processor: 2.6 GHz Dual-Core Intel Core i5, and 8 GB 1600 MHz DDR3 of Memmory. I am running macOS Big Sur version 11.6.1.
I am also accessing the drive per the following link:
