01R's avatar
01R
Luminary
Jun 05, 2018
realy high numbeer of correctbles in modem
whats it mean when modem has tons of high correctbles  ??
the uncorrectbles are ok i think
<tabindex=-1>Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 1 555000000 Hz -1.1 dBmV 39.1 dB 455 0
2 Locked QAM256 2 561000000 Hz -1.2 dBmV 39.0 dB 475 0
3 Locked QAM256 3 567000000 Hz -1.3 dBmV 39.1 dB 474 0
4 Locked QAM256 4 573000000 Hz -1.2 dBmV 39.1 dB 461 0
5 Locked QAM256 5 579000000 Hz -0.9 dBmV 39.2 dB 527 0
6 Locked QAM256 6 585000000 Hz -0.7 dBmV 39.3 dB 475 0
7 Locked QAM256 7 591000000 Hz -0.5 dBmV 39.3 dB 480 0
8 Locked QAM256 8 597000000 Hz -0.7 dBmV 39.3 dB 507 0
9 Locked QAM256 9 603000000 Hz -0.6 dBmV 39.3 dB 481 0
10 Locked QAM256 10 609000000 Hz -0.4 dBmV 39.4 dB 497 0
11 Locked QAM256 11 615000000 Hz -0.5 dBmV 39.1 dB 854 0
12 Locked QAM256 12 621000000 Hz -0.4 dBmV 39.2 dB 912 0
13 Locked QAM256 13 627000000 Hz -0.3 dBmV 39.1 dB 1110 0
14 Locked QAM256 14 633000000 Hz -0.7 dBmV 39.0 dB 1201 0
15 Locked QAM256 15 639000000 Hz -0.5 dBmV 39.0 dB 1276 0
16 Locked QAM256 16 645000000 Hz -0.3 dBmV 39.1 dB 1583 0
17 Locked QAM256 17 651000000 Hz -0.2 dBmV 39.0 dB 0 0
18 Locked QAM256 18 657000000 Hz -0.2 dBmV 38.6 dB 1 0
19 Locked QAM256 19 663000000 Hz -0.2 dBmV 38.7 dB 3 0
20 Locked QAM256 20 669000000 Hz -0.3 dBmV 38.3 dB 3 0
21 Locked QAM256 21 675000000 Hz -0.3 dBmV 38.2 dB 5 0
22 Locked QAM256 22 681000000 Hz -0.2 dBmV 38.4 dB 3 0
23 Locked QAM256 23 687000000 Hz 0.2 dBmV 38.7 dB 4 0
24 Locked QAM256 24 693000000 Hz 0.4 dBmV 38.9 dB 2 0
  • correctables number is fine. These packets are getting fixed at modem.
    high uncorrectables are problem but you dont have it.
1 Reply
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
