Andreabona
May 18, 2016Aspirant
Recovered password not working
Hi there, After owning our router (R6300) for a few years I thought it was time to change the admin password to something more secure than "password." I changed it and set up questions for password...
- May 18, 2016
If neither work, then you need to reset the router to factory defaut and reconfigure. When you have completed this, you will be able to login with the default password, but make sure you change the both the router default password and the default wifi passphrases. With default passwords and passphrases, it's an open invitation for someone to take over your router, as all these default passwords can be googled.
RE: reset to factory default... If required, you can search for your router's manual here.
Andreabona
Ok will do. I assumed I would need to reset but figured I'd throw it out there just in case.
Thanks!
Thanks!
