bapjohn
Feb 05, 2020Aspirant
recovering files from a RN314 that is no longer online
Is thre a way to connect a 2018 Mac Mini running Mojave OS to thIs unit with it offline in order to extract files from it? It has been replaced as the main server at work, but apparently not 100% o...
Feb 05, 2020Guru - Experienced User
Please post in the ReadyNAS forum for your NG product:
https://community.netgear.com/t5/New-ReadyNAS-Users-General/bd-p/readynas-general
Good Luck.
bapjohn wrote:Is thre a way to connect a 2018 Mac Mini running Mojave OS to thIs unit with it offline in order to extract files from it?
It has been replaced as the main server at work, but apparently not 100% of the files got transferred to the new drive and I need to get into the drives somehow if at all possible.
bapjohn
What does your reply mean? I have UB, HDMI, SATA and ethernet connections on the back of the unit.
What are you sugesting?
- FURRYe38Feb 05, 2020Guru - Experienced User
Your posting in the wrong forum. This forum is for Cable modems and cable modem routers only.
The link I included gets you to the correct forum.
Good Luck.
