SP7760
Apr 01, 2022Follower
Remote boot for C7100V – Nighthawk AC1900 WiFi Cable Modem Router
How can I reboot my router when away from home?
michaelkenward
Apr 02, 2022Guru - Experienced User
The C7100V supports the Nighthawk app. A remote reboot is one of the things the app can manage.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
This means that you can set it up to support Anywhere Access.
You can read up on how to use this by checking the bit in the manual on Remote Management.
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
