Gunnerb52
Oct 02, 2018Follower
Remote Management not working in the Nighthawk app
I bought NETGEAR Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem Router Combo (C7000) Certified for Xfinity from Comcast, Spectrum, Cox. I am using it on the Xfinity Network. I enabled remote man...
vkdelta
Nov 01, 2018NETGEAR Employee Retired
1. NightHawk is not supported for Cable Products.
2. Remote-Genie is not supported for Cable Products. It is only for Routers.
If you need remote management, you can do it ONLY via HTTP and not via app.
