SSWaltersII
Apr 08, 2020Tutor
Remote Management via Genie or Nighthawk App.
To Whom It May Concern - at Netgear:
Can ANY of your Wi-Fi Cable Modem Routers be remotely managed via either the Genie Android/IOS App or the Nighthawk ANdroid/IOS App?
Your product pages suggest this capability - sadly, falsely.
Thanks.
I would post about this over in the NH app forum:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
I believe Genie app is being retired.Good Luck.
Thanks.
Duplicated here:
Remote management - of C7000v2 - via the Nighthawk... - NETGEAR Communities
By someone who does not seem to understand how the system works.
C7000v2 WiFiCableModemRouter can't access Remote M... - NETGEAR Communities
It is all in the manual under Remote Management.
.If it doesn't work, explain how it fails and someone might be able to help.
