Fix1tN0w
Apr 09, 2019Aspirant
Remote Management
Is the Nighthawk capable of being remote managed or not? I can't get a straight answer. I want the ability to reboot router from iPhone while out of town. Who can answer this and how? Please
Fix1tN0w
Incorrect, I have a Nighthawk C7000 device. Not in Netgear list for that app. I'm currently using NO-IP as DNS Service and it works. Can someone point me to correct setup for app to remote connect and reboot router? thanks
antinode
Apr 09, 2019Guru
> Is the Nighthawk [...]
_Which_ "the Nighthawk"?
> Incorrect, I have a Nighthawk C7000 [...]
An actual model number usually works better than an ambiguous
marketing description. Not "C7000v2"?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Remote Management".
- Fix1tN0wApr 09, 2019Aspirant
1. see attached image from my Router Model number. I listed this in my first post and you told me find the Model number.
2. I have the PDF users manual, its useless for what I want to accomplish
- schumakuApr 09, 2019Guru - Experienced User
Afraid, the model information is not visible in all views, for example on the mobile browser view it's not. Sorry for that rant then.
So head for the Genie App - as long as it remains available - it does what you want.
this answers the other original question. If you cannot see it, it is a screen grab from my iPhone saying..........."nighthawk does not support your Router model."
