Fix1tN0w
Apr 09, 2019Aspirant
Remote Management
Is the Nighthawk capable of being remote managed or not? I can't get a straight answer. I want the ability to reboot router from iPhone while out of town. Who can answer this and how? Please
vkdelta
Apr 11, 2019NETGEAR Employee Retired
No NightHawk Cable Routers currently are capable of "Remote management" from app. (future ones may but not the current ones).
It can only support remote HTTP mgmt if you enable it from GUI.
if you want a Cable gateway with remote mgmt, you might want to check CBR40 or CBK40.
