jpwalsh4me
Jul 17, 2020Aspirant
remove, disable shareready on C7000
I have just installed a Netgear c7000 cable model and wifi router and want to remove, or disable, the default Readyshare feature. This is unneccessary for my environment
- Jul 20, 2020
Great to hear. Glad that worked. Thanks for sharing. Mark your thread as solves so others will know.
Enjoy, :smileywink:
antinode
Jul 17, 2020Guru
> [...] C7000
C7000[v1] or C7000v2? Look for "Model" on the product label.
> [...] want to remove, or disable, the default Readyshare feature.
What leads you to believe that the ReadySHARE feature is enabled
now? Did you connect a USB storage device (or printer) to the
C7000[vX]?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for a
topic like 'Share USB Devices Attached to the Modem Router". Read more.
Panic less.
