jpwalsh4me
Jul 17, 2020Aspirant
remove, disable shareready on C7000
I have just installed a Netgear c7000 cable model and wifi router and want to remove, or disable, the default Readyshare feature. This is unneccessary for my environment
- Jul 20, 2020
Great to hear. Glad that worked. Thanks for sharing. Mark your thread as solves so others will know.
Enjoy, :smileywink:
jpwalsh4me
Jul 20, 2020Aspirant
Netgear was defaulting to the "Basic" option for ReadyShare. So, I downloaded Netgear's USB Control Center and unchecked "Run Basic when windows is active". That did the job.
Jul 20, 2020Guru - Experienced User
Enjoy, :smileywink:
