reb1121
Jun 04, 2021Aspirant
Renaming SSID on Netgear c6300
What is the easiest way to rename the SSID on a Netgear C6300 modem? I have followed the instructions from Netgear but nothing is working. I need help with this.
antinode
Jun 04, 2021Guru
C6300[v1] or C6300v2? Look for "Model" on the product label.
_Which_ "the SSID"?
Here's a radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Types of Logins" and "Specify Basic WiFi Settings". Further
reading might not hurt, either.
> [...] I have followed the instructions from Netgear [...]
_Which_ "the instructions from Netgear"?
> [...] but nothing is working. [...]
None of that is a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] I need help with this.
Clearly.
