rpuerto4's avatar
rpuerto4
Repeated disconnects
I've been having this issue for months, the internet just drops over and over and it is very annoying. Comcast has come multiple times and they check some things out tell me it should be good now and then leave but the problem persists. I took pictures of my box outside as I always thought the ground looked fishy but I don't know much about this. Please let me know what a possible solution would be or maybe a direction I can point comcast in to finally get this fixed. Thank you.
TimePriorityDescription
2021-9-14, 09:35:40Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:35:28Notice (6)WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INTERFERENCE
2021-9-14, 09:34:48Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:34:46Warning (5)Dynamic Range Window violation
2021-9-14, 09:34:15Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:34:03Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:33:46Warning (5)Dynamic Range Window violation
2021-9-14, 09:33:43Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:33:26Warning (5)Dynamic Range Window violation
2021-9-14, 09:33:10Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:33:06Warning (5)Dynamic Range Window violation
2021-9-14, 09:32:37Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:32:06Warning (5)Dynamic Range Window violation
2021-9-14, 09:32:05Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:31:50Warning (5)Dynamic Range Window violation
2021-9-14, 09:31:47Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:25:07Warning (5)Dynamic Range Window violation
2021-9-14, 09:24:16Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:23:44Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:23:27Warning (5)Dynamic Range Window violation
2021-9-14, 09:23:16Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:23:07Warning (5)Dynamic Range Window violation
2021-9-14, 09:22:44Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:22:08Critical (3)16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:22:08Critical (3)Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:22:08Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:21:57Warning (5)Dynamic Range Window violation
2021-9-14, 09:21:56Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:21:24Warning (5)Dynamic Range Window violation
2021-9-14, 09:21:24Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:20:49Warning (5)Dynamic Range Window violation
2021-9-14, 09:20:48Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:20:37Warning (5)Dynamic Range Window violation
2021-9-14, 09:20:36Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:20:05Warning (5)Dynamic Range Window violation
2021-9-14, 09:20:04Critical (3)Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:19:44Warning (5)Dynamic Range Window violation
2021-9-14, 09:19:43Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
2021-9-14, 09:19:43Warning (5)Dynamic Range Window violation
2021-9-14, 09:19:42Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:08:77:34;CMTS-MAC=2c:0b:e9:15:99:ce;CM-QOS=1.1;CM-VER=3.0;
  • plemans's avatar
    the t3/t4 errors are indicating line issues.
    And the dynamic range window violations indicate your power is going in and out of spec.
    Both tend to indicate problems with the line still.
    Got a screen snip of the cable connections page from the modem?
    • plemans's avatar
      Photos have to be approved by a moderator and it can take a while.
      click on "choose file" and add it that route
