Red15Baron
Aug 02, 2019Guide
Replace Qwest Q1000 modem with NETGEAR Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem Router?
Will the Nighthawk AC1900 (24x8) DOCSIS 3.0 WIFI Cable Modem Router replace my Qwest Q1000 modem without any problems?
Aug 02, 2019Guru - Experienced User
You need to ask your ISP to check to see if it's officially supported on there network. If it is, then you'll be fine.
Review the C7000 spec sheet for details to compare agains the Q1000:
http://www.downloads.netgear.com/files/GDC/datasheet/en/C7000.pdf
antinode
Aug 02, 2019Guru
Will _any_ cable-TV-type ("DOCSIS") modem+router replace _any_ DSL
modem+router "without any problems"?
No.
Why do you want to replace your Q1000?
Note that "Nighthawk AC1900 (24x8) DOCSIS 3.0 WIFI Cable Modem
Router" is not a model number, and your "Qwest Q1000 modem" is actually
an Actiontec Q1000 modem+router.
https://www.centurylink.com/home/help/internet/modems-and-routers/actiontec-q1000.html
Yes, CenturyLink calls it a "modem", but it's a modem+router.
> You need to ask your ISP [...]
Not really.
> My Setup [...]
Just as useful as the "ask your ISP" advice. Thanks for the clutter.
- Red15BaronAug 02, 2019Guide
I'm not very tech minded when it comes to these things, but I thought I need to upgrade my modem/router because of all the equipment we now have in the house that needs wifi. Door bell, games, computer, ipad, etc.
- antinodeAug 02, 2019Guru
> [...] I thought I need to upgrade my modem/router because of all the
> computer, ipad, etc.Is there some actual problem which you are trying to solve?
A device like a door-bell may use very few resources when it's idle.
Depending on the level of your DSL service, there's no particular reason
to believe that the Q1000 is your bottleneck.Even if the Q1000 were a problem, it's a DSL modem+router, not a
"Cable" modem+router, so a C7000 (or anything else with "DOCSIS" in its
description) would not be a drop-in replacement, if you expect to keep
your DSL service.And that's why it pays to explain the actual problem which you are
trying to solve, instead of asking how to implement some particular
"solution" which may or may not make much sense.
