desertstraw
Jul 31, 2015Tutor
Republic Wireless
I have a Model C3000 modem/router and my cell phone provider is Republic Wireless. My phone does not work properly on their system. They insist that something is wrong with the capabilities of my rou...
netwrks
Jul 31, 2015Master
To clarify.. Is this an issue with Replublic's Cell network, or with WIFI on the C3000?
desertstraw
Jul 31, 2015Tutor
I have four devices on my Netgear router; laptop, Roku, Amazon tablet, and Republic Moto X phone. There is little trouble with three of them. Republic is a new service, since also found with Google, which incorporates VOIP into the phone automatically. The way that it works is that automatically connects by wi-fi if possible and turns to cell towers otherwise. All this is done without user input.
From the beginning I have had one way calls and noisy calls randomly on wi-fi and failure to switch as needed. Speed tests with Ookla taken simultaneously on my laptop and phone show a difference of a factor of a hundred at times. Wifi analyzer does not show an interference problem. Comcast has checked and frechecked my connection. Republic has run extensive tests and concluded that the problem is with my router. They cannot say what is wrong with my router but have pretty much terminated assistance to me.
- netwrksJul 31, 2015Master
On page 44, ensure DISBALE SIP ALG is checked.
http://www.downloads.netgear.com/files/GDC/C3000/C3000_UM_21Aug2014.pdf
- desertstrawJul 31, 2015Tutor
I have done this, it did not solve the problem.
- cassio3Oct 07, 2015Aspirant
Basic procedure:
1. Listen to Republic Wireless patiently. This is an algorithim. It takes time to get right.
2. Reserve the IP address in your router.
3. Place this IP address in the DMZ.
