arza77's avatar
arza77
Follower
Jan 07, 2023
Reset my router to get to admin section
Okay I have a modem router combo c7800 $300 my problem is I had someone reset it and I can't figure out what the default username and password is to get into the router configuration. I would look at the Box or the router but I am handicapped and can't get to either. The firmware needs updated so I'm asking if anyone knows the default username and password it is not admin and password. Any help would be greatly appreciated. Thanks in advance.
1 Reply
  • plemans's avatar
    Default login: admin
    default password: password
    All lower case.
    they might not have fully reset it so push and hold for up to 30 seconds.
