evanpress's avatar
evanpress
Follower
Jan 09, 2025
Reset Password
I would like to check Security on my CAX80. But it tells me that my password is wrong and must be reset. If I do so, will it reset the password for my wifi network? I have 16 devices on the network and don't want to reset them all.
1 Reply
  • FURRYe38's avatar
    Are you checking with the modems web page with a PC and web browser?
    Can you log in that way?
    If you reset the modem and setup from scratch, as long as you use the same SSID name and password to set up during the setup wizard, your devices will reconnect.
