Ak1414
Aug 31, 2022Follower
Reset router c3700
I moved to new place year ago and I did not use this network since then I called xfinity to stop service. Today I called and setup my internet package. Now the problem is net gear router c3700 which d...
Aug 31, 2022Guru - Experienced User
You sure?
There should be a recessed reset button in back or under the modem marked by "Reset" some where there...
Its actually on the buttom of it, right in the middle. Page 102 of the manual has a photo of it.
https://www.downloads.netgear.com/files/GDC/C3700/C3700_All_MSOs_UM_EN.pdf
push and hold it for 7-15 seconds while powered on
