D0N
Jan 30, 2018Aspirant
reset SSID and security key
Router 20 feet from PC (where cable enters dwelling); can bring router to PC but not PC to router; if I bring router to PC must a cable connection be maintained? Router had reset to factory default....
D0N
Feb 02, 2018Aspirant
Apologize for not being clear. I'll try another way.1. my router reset itself to factory settings;
2. I would like to rerset my SSID and security key to what I had before the reset. 3. My problem is my desktop is twenty feet away from my router, so bringing the computer to connect to the router is impractical unless I can find a 20 foot ethernet cord! 4.So, if I bring the router to the desktop I can connect to the desktop but if I do that I will have to disconnect the cable;does the cable have to be connected for the reset to be completed?
5. At the moment my other computer, ( laptop) just crashed so I don't have that option until I figure out what I am going to replace it with. Any enlightenment would be appreciated thanks, Don
michaelkenward
Feb 02, 2018Guru - Experienced User
Have you looked into using the Netgear desktop genie?
