Mrbelk
Apr 04, 2021Tutor
Resetting Router Mode C3000
I was troubleshooting an issue and arbitrarily changed the router mode to no. This was a not so smart move. Now the router doesn’t show on my list of available networks. I’ve tried doing a factory res...
Apr 04, 2021Guru - Experienced User
connect 1 device to the c3000 ethernet port, disconnect the other devices from it. Then reboot the c3000.
Then go to 192.168.100.1
that should let you access the c3000 and re-enable router mode.
You can try a factory reset as well. Many times people don't push and hold for 7-15 seconds while powered on.
- MrbelkMay 10, 2021Tutor
I appreciate the tip and sorry it took me so long to get back to the issue. As it turns out my PC does not have an ethernet port and I cannot locate a USB to USB cable in my stash to see if I can connect that way. I also tried the reset button again. When I press, hard, the button does not seem to give at all, so I can't tell if the reset is actually working. Do you actually see or feel movement when you press the reset button?
- FURRYe38May 10, 2021Guru - Experienced User
You would need a USB to Ethernet adapter to connect to the modem with your PC.
Well, I feel stupid. Took another look at the bottom of the modem, with eyeglasses on this time. What I thought was a reset button was actuall a small screw with an indention, which led me to think that the indention was meant for the tip of an ink pin or gem clip. Upon closer examination, I saw a tiny hole. Tried using a straight pin to press into the hole. WaLa. Success. Model is reset! Thanks so much for leading me back to the bottom of the box.
