snowmizer
Jun 19, 2018Follower
REST API Availability
I have been having issues with our Internet connection. I can see in the logs when my connection drops. I'd like to be able to access the router to pull those logs into Splunk so I can do some trending and tracking over time. I could just look at the router however those logs roll over too quickly.
Is there a REST API available to pull this information from the cable modem?
Thanks.
1 Reply
- vkdeltaNETGEAR Employee Retired
nopes. there is SNMP access but it is blocked from LAN side due to security reason and not allowed to be open due to ISP restrictions.
you probably need to devise some curl scripts to read the data. But I am not sure due to security protections if it will work 100% OK...
