BHnSD
Mar 26, 2020Aspirant
Restrict LAN access to certain devices
I have a storage device connected to my modem and I only want known computers to be able to even see that storage device. I know it is password protected but I don't want it to even show up on the network for guests or certain devices connected to the WiFi. Is there a way to restrict that? I have already Blocked the storage device from all services.
1 Reply
Usually LAN side devices are accessible thru out. Unless you put in managed switch and setup a VLAN configuration, that may work. Otherwise devices can see each other. If you have it secured and noboby has access, you'll be fine.
Check with the NAS's mfr for additional help and information on this as well.
