ChestnutBestnut
Sep 01, 2022Tutor
Reviving a bricked C7000v2?
Hi all! First time on this forum, since I've run up a bit of a crazy road trying to figure out how to revive my (quite new and not super cheap!) C7000v2 / Nighthawk AC1900 modem-router combination un...
- Sep 05, 2022
Might be bricked then
michaelkenward
Sep 02, 2022Guru - Experienced User
ChestnutBestnut wrote:
Hi all! First time on this forum, since I've run up a bit of a crazy road trying to figure out how to revive my (quite new and not super cheap!) C7000v2 / Nighthawk AC1900 modem-router combination unit.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. In this case, you need advice that only cable modem experts are likely to know about.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
