ChestnutBestnut
Sep 01, 2022Tutor
Reviving a bricked C7000v2?
Hi all! First time on this forum, since I've run up a bit of a crazy road trying to figure out how to revive my (quite new and not super cheap!) C7000v2 / Nighthawk AC1900 modem-router combination un...
- Sep 05, 2022
Might be bricked then
Sep 02, 2022Guru - Experienced User
it sounds like you might have indeed bricked it.
Its one of the reasons we don't usually recommend combo units on here is when you do brick them, there isn't much an end user can do to recover it.
You've tried resetting with the coax disconnected?
You've tried the 30/30/30 reset?
The only other thing I'd recommend trying is to bring the c7000 to a different location with the same ISP and see if they can provision it there. Maybe there's a line issue and its not fully provisioning it.
IF that doesn't work, you'd want to start an RMA process if you're still within warranty
ChestnutBestnut
Sep 02, 2022Tutor
Regarding location swap - got it, makes sense!
Plemans -
- Sadly it's outside of the Netgear warranty by two weeks, and the tech support is pretty limited beyond 90 days. Wish I'd known about the modem-router combo shortcoming before buying!
- Talked to Netgear support for a hardware check, and they seemed to think it wasn't a firmware issue if there were lights other than the power LED illuminated, and if the power LED was illuminated green rather than amber...is it possible there's any other class of issues that could be at play?
- Just tried the reset again with coax removed, and also the 30/30/30 with coax removed - no dice
- We've had a separate modem and router here from prior roommates (who are moving out and now want said items) that worked well enough on this coax connection (although they did have intermittent outages) - do you think it's still worth trying a different location given that prior hardware worked?
Question: When the ISP sends a reset code, is that the same as them forcing a firmware update / reinstall? Or is it worth trying to go back again and specifically request a firmware reinstall?
As an aside, new observation: The lights blinking once (randomly) actually aren't connected to the reset button; they just happen every now and then while it's plugged in.
Thanks very much for your help!
