interessant
Mar 27, 2026Follower
Right now i can not log in to router to see the settings i set
using it right now ....however found info ....port forwarding ....right now i can not log in to router to see the settings i set..... posts on netgear webside got deleted....
CrimpOn
Mar 27, 2026Guru - Experienced User
interessant wrote:using it right now
One of the problems with piggybacking on a conversation that ended seven years ago is that the context is essentially ambiguous. i.e.
- Is this about a Netgear C6250 ?
- Have you purchased a DOCSIS 3.1 modem and connected it to one of the C6250 Ethernet ports?
If so, specifically what modem is this? - How have you established that this is "working"?
- How are you not able to log into the router?
