ghorky
Feb 03, 2021Aspirant
Ring Doorbell 2nd Gen and Netgear C6300v2 Internet Connectivity Problem
Hello, Is there anybody facing a problem during setting up Ring Doorbell 2nd Gen? My Router model is C6300v2 and I could not make my Ring Doorbell 2nd Gen setup successfully. It is always givin...
ck_ck
Aug 09, 2021Aspirant
I have the same problem.
I have a two ring security camera's which will not connect to my C6300V2 Netgear router. I contacted ring, xfinity and netgear and no luck. Same ring camera's work with different router.
Things i tried:
1.Connecting to different router - works good
2.Connecting to 2.4 with WPA2-PSK [AES]
3.Connecting to 2.4 unique ssid with no security
4.Reset ring multiple times.
5.provide static ip
6.Setting Port forwarding.
7.Factory reset my router.
Netgear customer care is suggesting to buy a network clean up package(close to 220$ for a year) to resolve this, do you guys think that is legit?
