Laura_82's avatar
Laura_82
RMA Process Complaint
Product: AX2700 DOCSIS 3.1 WiFi Cable Modem Router(CAX30) I wanted to take a moment to voice my dissatisfaction with your current RMA process.  I purchased a netgear cable modem/router over the stan...
  • plemans's avatar
    Mar 11, 2022
    A couple things.
    1. we're the public support forum where members of the public help out. We're not netgear.
    2. The warranty info is on the site. I believe it is also on the documentation for it. As much as it sucks, it isn't hidden.
    HARDWARE WARRANTY | PRODUCTS COVERED BY WARRANTY | NETGEAR
    3. AGain, putting it on here so others know is a good thing as it can help others who're wondering about warranty/rma issues. But if you're wanting results, your best bet is support and/or a supervisor on there.
