severedowntime
Aug 01, 2023Aspirant
Rolling back firmware for C3700
My C3700 is now only allowing my computer to ping websites which have IPv6 addresses. I suspect that Xfinity pushed a firmware upgrade onto it Monday, as it was working fine in the morning, but was u...
Kitsap
Aug 01, 2023Master
The current Xfinity firmware for the C3700 is V2.02.23. Reference page here:
Firmware for the C series of cable modem/routers is strictly under the purview of the ISP. Nothing the end user can do one direction or the other.
If using Windows, have you checked the network profile assigned to your connection? It should be classified as Private as opposed to Public. Go to Settings -> Network & Internet -> Status -> Properties.
severedowntime
Aug 02, 2023Aspirant
Thank you for your response, but I wasn't able to make it back from work early enough today to try it. My roommate bought a new modem while I was out, so I can't say for sure whether this fix would have done the trick. Thanks for the tip, though.
