iMcGregor
Jun 28, 2021Tutor
Router Access Problem
I have been unable to reach the site routerlogin.net on both my phone and PC. When I attempt to reach using my phone I receive the message unautorized access; doesn't allow an opportunity to input an...
- Jun 28, 2021
A couple things.
1. many people just reboot or click the reset button. It needs to be pushed and held for up to 15 seconds while the devices is powered on.
That'll get it back to defaults that you're entering.
2. the C3700 is a dual band N600 device. Meaning it has both 2.4ghz and 5ghz and they work at the same time. You don't need to set a preferred band on the router, you just need to connect to the 2.4ghz band instead of the 5ghz on your devices. (provided you didn't set it up using the same SSID).
3. Why are you wanting to "prefer 2.4ghz"? its a slower band and more sensitive to interference. Maybe a better understanding of your actual issue might help.
Jun 28, 2021Guru - Experienced User
A couple things.
Might also get better help in the cable modem/router forum versus the business class Orbi forum.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
