theH2o
Jan 10, 2019Follower
ROUTER ACCT LOGIN FUSTRATION
I'm trying to get into my Router Account to get to the genie parental controls, but it says "invalid username or password", i've tried everything, loging in with admin-admin, admin-password, etc... b...
DarrenM
Jan 23, 2019Sr. NETGEAR Moderator
If you cant login in you will have to factory reset the router by holding the reset button for 10+ seconds then it will be admin-password.
DarrenM
- WillyKotFeb 11, 2019Aspirant
I try to reset the password and when I do I only get Chinese characters with no way to change the language. What can I do - I don’t want to reset everything again.
